- Oct 18, 2001
1. On a precision folder, do you drill the pivot hole before or after heat treat? I would imagine that drilling before heat treat would mess up the hole with scale, or change the dimesions slightly. Drilling after heat treat would require tempering the area at a higher temp.(no big deal w/ a torch).
2. How hard should the pivot area be?
3. Do you drill pin holes in fixed blades before or after heat treat? I would think they would require less accuracy, therfore before would be ok.
