J. Hoffman
- Jan 1, 2011
When I'm using Corbys or Loveless screws on my handles I mark the position for the holes, and drill the smaller hole all the way through the handle material. I do this separately for each scale. Then I drill out the larger holes, about half way through the scale. The problem I'm having is centering the larger hole over the smaller hole. I've tried putting the larger bit into the hole to center it, but it doesn't work? Should I be drilling the larger hole first, and then drilling the smaller one? What I have done to this point when this happens is take a chainsaw file and slightly enlarge the smaller hole so the bolts fit. I don't like doing this because I think it could weaken the holding power of the bolts. If photos would help, I can take some. Thanks in advance.
Jess
Jess
