- Mar 12, 2010
Hi All,
Coming from the Northern Hemisphere, cold weather, snow, and all that comes with it is a reality that needs to be respected. These elements play a very crucial role when it comes to the gear selections that I make. The gear I use needs to be tough, which is a big part of why I like ESEE...
One of the challenges that I've faced when it comes to my gear choices when I go out in the bush comes from the need to wear many layers. This inhibits your mobility to some degree, depending on how cold it is and how much snow you are getting. In addition to limiting your mobility, it also means you are going to burn more calories, which means you need more food and more water. You need more insulation to make it through the night, so you are going to need a bigger pack. Fires are going to be more challenging to light, and will need to be larger to provide the warmth needed to make it through the night.
One small little detail that I've been working on mastering is figuring out where exactly my knife should go on my person. The most obvious choice is vertically on my belt in the sheath, but due to the many layers and the large pack with a waist belt, it is often cumbersome to get to it. In the summertime, when I have less clothing and less gear, it's not so much of an issue. But in winter, my knife is harder to access from this point.
I got the idea to try a drop leg sheath, and I recently stumbled across one at a local Army Navy Surplus store. I decided to purchase it, because it was a steal. It enables me to lower the knife on my person about 6-7 inches, and my pack belt and jacket no longer obstruct the knife as I sheath and resheath it. The webbing also enabled me to attach another small M-16 Mag Pouch to it, which easily fits an altoids tin, and also happens to perfectly fit my Stanley Whisky flask...
This is a little more "tacti-cool" than I like, since I'm more of a traditional guy, but it solves a problem that I've been faced with very well. I'm able to run with it on, and my hand at rest on my side is at the perfect level to grab the knife handle.
I don't know much about this company or drop leg sheaths in general, but this one seems to do a good job at solving a problem I've had. It was made by these guys... http://www.specopstech.com/home.html
Now I'm just going to review some posts by Texas Tony Dobbs and others to try my hand at downsizing some of my gear so that I can make a kick butt PSK for my altoids tin and I'll be good to go.
JGON
JGON
