Dry Damascus Weld Question
My question is regarding dry welding billets together without flux. If all surfaces are surface ground flat and then all 4 pieces are TIG welded together tight without using any filler rod, do you have to grind all welded surfaces after the initial WELD fusion process?
I hope to eliminate the grinding part after WELD Fusion of all the MIG lines.
