- May 25, 2007
I always carry my gear in a drybag slung around my shoulder when hiking.
Apart from a small survival pack on my waist most is stuffed in a large drybag. Inside the drybag there is another bright yellow one, rolled up tight. Does anyone use this more often in the wild? Those bags are supertough, completely waterproof, and can be used as an improvised water or fuel bag, tinder, food or game collection bag, a cushion, an improvised floatation device that keeps your cloths and boots dry when crossing a river or in a sudden flood situation. in a bright colour as a signalling bag, etc.
These bags can be used to shield your body from moisture The biggest ones even let you put in your legs partly and stuff the inside with insulating materials or can be used to sleep on stuffed with insulating material to shield your body from the cold and moisture. They can be used as bear bags, because they are water and airtight so they don't transmit food odours too easy. If you buy a black one you can use it as a solarbag to "heat" water in the sun. Or with a dessicant gel inside these bags can be used to store guns, or valuables very low profile. If you place these bags with the family fortune inside, say a nice stapled logpile outside your house or cabin nobody will think you have anything to hide there. These packs are pretty low profile and don't transmit agression, wealth or high social status letting you blend in during an emergency.
I would rather walk dressed in earth tones with two black bags slung around my shoulder in an urban emergency, then walk around in military fatigues, with an expensive state of the art backpack, and shoulder rig around transmitting , hey this guy is either wealthy or prepared well so he probably has valuable stuff with him.
The ony real drawback imho is that they are slow to get into. You can buy them in smaller yellow orange or green units , and write down the contents on them , so you don't have to rummage thru your large back to find anything loose, and they are absolutely waterproof!
i always use ortlieb bags http://www.ortlieb.com/index_white.php?lang=en&m1=0&m2=0&file=p-search.php and http://www.ortlieb.com/index_white.php?lang=en&m1=0&m2=0&file=p-search.php
