Where you located?Hello, new here and would like a recommendation for a sharpening service to get my eskabar back into shape. Thank you .
Lansky diamond turnbox is dead cheap and easy to use. You won't ever have to send off a knife again.Hello, new here and would like a recommendation for a sharpening service to get my eskabar back into shape. Thank you .
Ahh, was gonna say if you were near me I'd sharpen it up for you..Beckers take an excellent edge...I'd personally go with the sharpmaker over the similar styled lansky one. Also simply using sand paper will get you a nice sharp edge, if you use it over a mouse pad you can create a convex edge which you can easily maintain with a strop.Hi, Bobby. I'm in Tucson AZ.
Are you sure? I pulled this off a post here on the forums.If it's truly 'dull', the standard Sharpmaker rods aren't going to work very well. The brown medium rod is 1000grit. The white fine rods are 2400.
But 1095CV is not that diificult to sharpen so no need to buy the diamond/CBN rods. Just wrap the standard rods with 200~500 grit sandpaper.
Pretty sure.Are you sure? I pulled this off a post here on the forums.
Regardless, having tried to sharpen dull edges on the SM Medium rods, I know it's a waste of time.![]()
Magnaminous_G said:If you want to get the SharpMaker, that is fine, too. Its a great system... with a few caveats. You will need the diamond or CBN rods if it is going to be your primary system (and those cost as much as the basic set), so youll have to spend about $110 total if you are buying new. And youll have to modify your technique. I do not recommend the Spyderco DVDs because Sal does not demonstrate sharpening a totally dull, dinged up knife from start to finish. (There's a reason people jokingly call it the "SharpKeeper.") But thats exactly what you are going to be doing. The official one-stroke-alternating style will simply be too slow (see the video I made years ago below, which is also mentioned in RayseMs post above -- I did not invent this method. I learned it from CrimsonTideShooter, aka J. Davis). If you try to sharpen a truly dull or damaged edge the official way (especially if you are using only the stones they provide you with the base system), it will just be too slow to be worth your time that way when there is a much more efficient way to do it.
Magnaminous_G said:Common question: Is the Spyderco Sharpmaker a good system, and can I sharpen a dull edge (i.e., reprofile) with it?
Answer: Yes! But I strongly recommend you get the diamond rods. Check out the vid below to watch my technique for reprofiling a dull, damaged factory edge with the Sharpmaker. It can indeed be done and done quickly. With the diamond rods, the Sharpmaker will do everything you need a set of stones to do. They are expensive but worth every penny. A note on the ceramic rods that come with the set: the stones are very hard ceramics and need to be cleaned every few uses. Use a scouring pad. They are also quite fragile, so dont drop them or treat them roughly. Lots of people have chipped or broken their Sharpmaker rods by accidentally dropping them. Spyderco has good customer service (in my experience) and will replace a rod if it is chipped from the store (and they sometimes are, especially the brown medium rods).
