- Aug 20, 2019
so i'm still firmly in the stock removal part of my blade making journey.
simple profiles are easy, but i never like easy (apparently) so currently i'm making a hand axe/knife thing.
i'm actually trying this on a circular saw blade that I know will harden because i've made a blade out the other part of it and tested that.
But it's also free donor material to learn with so when i get known material if i like this pattern and think it's useful will move on to that.
So stock removal with the shape i'm going with is a little bit of a pita, this is a very rough cutout still refining it.
photos.app.goo.gl
so not for gross removal, but I was wondering if I took my router table, and put in a bit like this
would doing some stock removal for the inside part of that be crazy to attempt with that, (or overly dangerous). I mean i'd cut most of it out with an angle grinder, in this case it took a bit of careful worth with that to get that inside shape but was thinking the very rough inside hole use the angle grinder, use the burr bit fo rmetal for the general shape and then use a sanding drum bit to get it refined.
New item by Carl Christianson
photos.app.goo.gl
