Cliff Stamp said:ZDP-189 is an loose translation anagram of "folded metal". The 189 refers to the "effective" number of layers for a loose comparison of traditional hammer forging/folding steels. The Japanese were not content with the size of the large carbides found in high alloy stainless stainless steels. Even in the P/M steels these can approach 10 microns when the carbides aggregate to form macro-carbides and this leads to a low edge stability, ideally you want sub-micron carbides.
They also wanted to find a way to increase the wear resistance without using vanadium as that has problems with lower edge sharpness due to the very hard carbides having lower edge integrity as they require a higher counterbalance force to be cut than chromium rich carbides. They looked towards forging which is to be expected given their history of sword steels and thus was born the ZDP process, which is also called "metal ceramic technology".
Here is a shot showing the very fine carbide size and high distribution in ZDP-189 :
-Cliff
hara-kiri-yogi said:Maybe i know more about single malts though ...
mmarkh said:Thanks Cliff.So what you are saying is ZDP does'nt really stand for three different words but a type of blade steel,right?
Patapsco Mike said:At some point in the future, wewill run the test again to see how far beyond 100 cuts ZDP can go, Thron-burg noted. But for now, ZDP-189 socompletely eclipsed the performanceof conventional steels, we had our an-swer.[/I]by BLADE® staff
original question was forgotten
