I've never used S60V, but in recent hunting expeditions with CPM M4 (and cutting abrasive materials with S90V) I have found polished worked good, but with CPM M4 it actually cut better (as skinning is pure slicing, not push cutting) as the edge wore and got some tooth in it. I've found in S90V a hair popping edge with a DMT Coarse slices great and lasts pretty long, but a better compromise might be a 1200-2000 grit edge with a light stropping to remove any burrs and make the edge a little finer. Again, I'm not sure about S60V, but I know S90V likes a coarser edge than M4, but both do pure slicing cuts better for me when not polished to the moon. As I've found out M4 at .05 micron will easily take a pig apart and be ready for more, but again it seemed like a bit coarser edge would have been a better finish for the pure slicing cuts of skinning, but you can pretty much count on those Vanadium carbides that fill S60V will definately get exposed as you cut more, so even polished to the moon the knife should end up wearing into a toothier edge that slices better for you if it starts out polished to the moon, but you will just have to use more force initially to make the cuts in my experience.
Mike
