blgoode said:seems like a topic that would be ironic but trueDust killed my dust collector
Chant said:I just had a near-unpleasant experience as a result of my dust collection system.
Due to the sparks and hot metal given off by my grinder, I had set up a metal duct-work system for about 4 or 5 feet before hooking up to the vacuum unit. I liked the idea of the transparent pipe, but didn't figure it would be a good idea with the sparks.
Anyway, the system seemed to be working fine, but today I took my respirator off for a moment during a pause in grinding, and smelled smoke.
Turns out that a lot of the heavier grindings (the stuff that looks like steel wool) had been accumulating along the bottom of the length of piping, especially at the corners. Sawdust from grinding handles had also got mixed in with the accumulation.
Well, you know what happens when you put a match to fine steel wool! I had a small "stove-pipe" fire going on. Lucky I had paused and removed my respirator, as I couldn't smell it with it on. If flaming debris had made it to the vacuum system, I probably would have been getting out the fire extinguisher. As it is, I just turned off the vacuum, uncoupled the pipes, and dumped out the smouldering mess on the concrete floor. I was suprised at how much had accumulated in the pipes.
So...if you're using non-transparent pipes or ducts for a dust collection system from your grinder, be careful, and make sure you clean it out after every major grind. Maybe if I had a stronger vacuum, it wouldn't be a problem, but I suspect grindings would still accumulate at the angles.
jhiggins said:The best thing I have is a setup which incorporates a booth that my grinders reside. There is a large 18" industrial wall fan, drawing all airborne dusts to the outside. The booth is set as part of my shop, and does pull a lot of heat out of the shop during the winter, but it keeps the rest of the shop clean, and all heavy particles of dust fall into a water tub beneath the grinders. This is the only way I have been able to sleep at night, knowing that nothing is going to burn down.
