Will the dye soak into a block, or is this for scales mostly?Dye the wood first in an alcohol based dye ... then after drying have it stabilized, or use your cactus juice.
This way you control the color and aren't making a crap shoot about what the color will end up being. It also doesn't ruin the stabilizing agent e for other stabilizing.
I was told by K&G that they just let it soak. I might just do a little experiment on a small piece using food dye to try to get an idea of penetration without pulling a vacuum on it (curious minds...)A pressure/vacuum pot will make it much better.
I might get flamed for being too technical here, but ... if you do the “dye soak before stabilizing” approach, you really need to use either a water based dye or an alcohol based one (as stacy said). The reason is that the material in the wood is hydrophilic (water loving) ... it will soak up water based dyes, and those dyes will adhere to the inside pore surfaces (same with alcohol based dyes - as alcohol mixes with water - much to our enjoyment this time of year). An oil based dye is kind of like the epoxy resin . It will need to be “pushed” into the wood pores by pulling a vacuum and then applying pressure ... and also it will not adhere to the pore surfaces (and also water or alcohol will evaporate after soaking,and oil will not).I am really interested in this. I can experiment with soaking only before I manage to finish my chamber. Also DIY dyes (food coloring, printer ink, eye shadow and similar).
What does ot resin stand for?Just a comment, but if you want to dye wood .... use wood dye.
Food coloring, paint coloring, tempera paint, model paint, etc. are ot resin or wood dyes.
I'm pretty sure that the 'ot' is 'not' misspelled.What does ot resin stand for?
