Dykem clogged
All,
What do you do when the Dykem spray gets clogged?
Thanks,
JD
If it is the pickup line that is clogged there is not much you can do. The only thing to try is to get a clean out nozzel from Brownells and see if it will allow the clog to be cleaned.
If it is the nozzel that is clogged (much more likely) it is easy to fix. Simply remove the nozzel and let it soak in some solvent (I use acetone). I store my solvent in a liquid container squeze bottle, so once the nozzel has soaked I insert it into the tip of the bottle and squeeze until I get the solvent spraying through. Fixes clogs every time.
Be sure to clear the nozzel, by turning the can upside down and spraying until just air comes out, after every use.
