Cliff Stamp
BANNED
- Oct 5, 1998
Much is made about chosing carbon steels for "field" knives due to ease of sharpening vs stainless steels and in particular dropping the hardness for the same reason. This is usually based on more myth than reality and has more to do with how the knife in ground rather than what it is made from.
I took an Endura, VG-10 stainless, at 59/60 HRC, sharpened but slightly used, it would press cut 3/8" hemp with 30 lbs, and had little aggression on a draw as it was highly polished. It could almost push cut newsprint and slice it readily. Optimally it should push cut the hemp with ~25 lbs, and make a draw with significantly less force with a medium finish.
The knife was used to cut a one foot square sod in the most brutal way possible which was use it like a root saw, the edge was constantly grating over rocks, and then the sod was skinned off. The knife then had no push cutting ability on the hemp, 150 lbs didn't even score it, and it took 30 full length slices at 30 lbs to make a cut.
I then sharpened it with thiry seconds per side on a concrete block :
http://i7.photobucket.com/albums/y269/CliffStamp/Spyderco/endura/endura_dirt.jpg
I would then make the hemp slices in 2-3 blade lengths, could push cut with about 90 lbs, and easily cut newprint on a draw :
http://i7.photobucket.com/albums/y269/CliffStamp/Spyderco/endura/endura_newsprint.jpg
I spent a few more minutes seeing if the performance could be refined, but the problem was the concrete had large rocks which would pretty much mash into the edge and flatten it, you need a section which is mainly sand and there was none on this block.
I did the same thing years ago with a Fallkniven VG-10 blade, to much the same result. It isn't difficult to restore stainless blades to a decent level of cutting ability (the knife easily cuts fabrics, slices vegetation etc.) on really basic materials.
About a half an hour or searching allowed me to find a flat rock which got it to cut the hemp rope in under a full slice, of course if you live in Arkansas this is probably a lot easier to do.
-Cliff
-Cliff
