Jerry,
You sure ordering 1084/1095 from the supply houses is a good idea for a newbie with files?
A lot of the 1084/1095 from the supply houses doesn't come annealed. Either that or it isn't fully annealed. I spent in excess of two hours drilling and filing a slot for a guard I made out of 1084, and I was using almost brand new Nicholson files. The 1084 also ate my drill bits. The outside part of the steel drilled easy, but the minute it got into the inside area, the drill would just spin, make the loudest shrieking noise you ever heard, and burn oil. Unless he can anneal the steel, it may actually be better off for him to order a piece of 440C from the supply houses. I've filed bevels on 3/16 thick 440C before, it's not too hard, and it drills like butter compared to some of the hot rolled carbon steels I've tried.
