- Feb 4, 1999
Well, I finally bit the bullet and tried to do a Japanese style clay heat treat on that tanto. I think I may have just pulled it off, although I doubt I got a very consistent critical temp on the blade. A file skates off the edge, so I guess I did it, but I can hardly believe it. That's the last big blade I do until I get a proper heating forge made or something. Sheesh. Anyway, I couldn't find "refractory materials" in my yellow pages, and I got a recommendation to try Red Devil furnace cement, but I couldn't find that either. I went to Lowe's today and found fireplace caulk stuff in the Caulk/Adhesive ailse. It's supposed to be good to 1400 degrees or something, so I thought I'd give it a shot. I think it actuallyu worked! It comes out real runny at first, so squeeze it until it comes out like toothpaste (it's in a regular size caulk tube sort of format. Sells for $2.75). Anyway, I spread it on with my finger about 1/4" or so, let it dry (less than an hour) and applied a bit more to get a pattern and get even thickness on the part of the blade I wanted to stay soft. I didn't wire it up or anything and it adhered to the steel with no problem at all. Good stuff. Anyway, I can't really tell you how it did because I don't have an Rc tester, but I can see a nice hamon with the blade finished to 220 grit or so. I am tempering the knife right now, so we'll see how it progresses, but this could be a good resource for people who want a cheap and easy alternative to satanite and that sort of stuff. I'll keep ya posted!
