Looks to me like 2 natural stones, a.k.a., 'Arkansas' stones, glued/epoxied together. The side with the more noticeable figuring/grain looks like maybe a medium-hard grade, and the other, more uniformly light one looks like a 'soft' Arkansas (sheds grit more easily in use), OR, maybe a so-called 'translucent' Arkansas, which is a finishing-grade, hard stone. 'Translucent' implies it'll pass some light, if you hold a bright light near the edges/corners of the stone. If these are Arkansas stones, they would be OK for use on simpler steels, like 1095, CV or low-alloy stainless like 420HC. Wouldn't work as well on more wear-resistant steels though. It's very common for such 'natural' stones to be paired in such a wooden box as shown.
Might wait for others here to chime in as well.
They need cleaning. DM
Good idea! I’m trying my hand at sharpening a cheap pocket knife of it now... much more challenging then one would thinkLooks good. Next time I would just use Comet with water and a brush. DM
I like watching “rough rooster knife sharpening” on YouTube and I was following along with him when he lapped a couple stones with the wet sandpaper, I think I lucked out with the stones they look real flat I can’t see any sort of dishing.Those do look good.
I've used the coarse side of a dual-grit SiC stone, with water, to clean up & flatten my Ark stones. That works pretty well also.
Can also use Bar Keepers Friend powder, with water, to make a paste and scrub the stone with that (using an old toothbrush). The oxalic acid in the BKF powder will dissolve the iron swarf, which makes cleaning much, much simpler - not as much 'elbow grease' involved.
