Ebony, will it crack?
Hengelo_77
Basic Member
I know that real ebony wil crack if it gets to hot.
I've also heared that ebony will always crack over time.
Is that so?
Is it save/wise to use ebony for a handle?
I have ebony carvings from Africa that I have had for over 30 years. They have not cracked. I used a piece of Ebony for a forearm on one of my rifles 35 years ago. It has not cracked. I have used it on knife handles and have not heard of it cracking. I think it is important to let the ebony get dry before it is used. Others may disagree, but that has been my experience.
The only time it's an issue is if you move it to a drastically different climate. Coating it in wax to acclimate for a month would probably prevent most problems. I have 30 year old ebony that isn't cracked.
plenty of high end guitars have ebony fretboards .In the guitar literature lemon oil is often recommended to wipe down the fretboard when it's made of ebony .
I have a ebony handled dagger from MS Michael Connor that had a micro check when I first bought. Every summer here in Las Vegas it opens up to at least and 1/8" thick. I soak it in mineral oil once a week. I mean completely soak it. I pour oil in a glass and submerge the handle completely and leave it. It still moves. I have two other knives with ebony. One is a boot knife by MS Gann with a checkered handle and I have never had a problem with it. I think the one I have a problem with was not completely dry before it was worked. One was stabilized by Dusty Moulton and I have never soaked it in oil and have never had a problem. So it all really depends on the condition of the wood before it was turned into a handle. I would highly recommend you stabilize any ebony if you are going to use it.
I have used Madagascar ebony on 3 or four knives and still have one. Never a problem. My Weser Brothers piano dates back to 1894 and has ebony keys...never a crack. I think if it is dried properly and it is not cracked after drying that it will be fine. I have never used Gabon ebony however and cannot speak to that. Off the subject a little bit, when I first started making knives I bought some laminated ebony "diamondwood" from Jantz knife supply. I am not sure if it is even real ebony but it is more costly than the other diamondwood by about 4 times as much so it could be. Anyway, it makes a beautiful knife and is as hard as a rock. It needs no sealer or oil and can be buffed to a warm glow as I prefer or a downright shiny finish. I read that the leader of Madagascar wants an embargo on woods from his island but do not know if it has been done. I bought three nice blocks last year from an exotic woods dealer that I am saving until I find out if I can get some more. If any of you have a recommendation on obtaining good ebony at a reasonable price please share your knowledge.
Ebony that has been properly dried is a great handle material. It has been used as such for hundreds of years.
Ebony does not naturally contain mineral oil, and using mineral oil on wood will soften & ruin it. Don't use it on ivory, either.
Use paste wax instead.
What gives ebony a bad reputation is that too many new makers put it on a handle and go straight to the grinder to hog it into shape, rapidly sand up the grits, then power buff it to a high shine. This drives out all the resins and heats the wood up a LOT. The wood was lovely when done. but cracked or checked later on. The problem isn't the ebony, it was the techniques used to work it. Ebony is often called "black ivory", because of the way it looks and how it is worked. Treat it like ivory and you will get great results. Mistreat it, and just like ivory, it will have cracks and splotches.
Grind ebony slow and with fresh belts. Sand to a fine finish and buff gentle ( or sand and buff by hand). Paste wax puts and keeps a lovely shine on ebony. Oils should be avoided. African blackwood is a good ebony alternative.
A few words about ebony:
Many carved "ebony" objects are not ebony. Some is dyed African hardwoods, and some is ebony relatives dyed or painted to look like Gabon ebony. Ebony is a large family, and most is not black. Some is white and black striped. Persimmon is an ebony, and has been dyed and sold as "ebony".
A lot of ebony sold by wood suppliers, even the biggest ones, is dyed. Some is also not fully cured. Be cautious of heavily waxed ebony, as they use a black wax to make the blocks look darker. In grinding/sanding dyed ebony, you may actually stain your hands black when working it. Some of this wood isn't even ebony at all.
Buy ebony from an exotic wood dealer who knows his ebony. He will know how long it has been drying and where it came from. The big name wood suppliers and woodworking chains often just buy whatever is offered at a good price and have no idea about what it is or where it came from. They may label it all "Gabon" ebony. I have found that a good wood supplier will happily answer this question with yes, "If I am not satisfied with this wood, will you replace it or refund my money?"
Good ebony is not cheap...and if it is cheap it is almost assuredly not good ebony. Old ebony furniture is often quite brown once you cut it up. The wood may or may not be ebony, and the lovely black shine is usually a varnish or other surface finish. Even expensive pianos are like this. It is always worth the effort to see if an old thing can be re-purposed, but be aware that it may not look the same inside as it does outside.
Ebony will turn a lighter brown and/or show stripes when sanding, but should turn dark again when finally sanded to a fine surface, then buffed and waxed, if it is the real deal.
Sand to as high a grit as you have for the best shine and depth of surface. The better the sanding the better the finish. 1000 is a minimum, 8000 is not totally crazy. If taken by hand to an 8000 grit finish with the 3M papers, a hand buff with wax on a soft cloth is all that will be needed to finish the job.
Avoid power buffing with white rouge as it can make tiny white flecks in the shiny black finish. A clean muslin/linen/cotton buff with some carnuba type buffing wax on it is great for getting a high shine on well sanded ebony. Use light and quick buffing passes, and use the very minimum of any compound.
I was at a wood supply store once and they had blocks of wax coated ebony. The wax was completely black and very thick. I asked if they had some without the wax on it. The salesman said the wax prevented the wood from cracking. I asked what would prevent the wood from cracking when I made something out of it. He looked dumbfounded! I have also asked sellers online to sand the wood to a smooth surface without wax and send a photo. Most refused, as they knew that the wood would be brown, not black.
When I was in school I carved a bowl of ebony.TReally knew nothing about it then.Not too long ago my brother sent it to me .But after the years it had developed numerous cracks .Too bad !
I still play a bass guitar that I built almost 15 years ago, and it has a macassar ebony fingerboard that I cut from lumber.
I still have scraps from that fingerboard that I occasionally use for knife handles, and it has stayed in superb condition throughout the years.
I live in the desert, and when my band was pro gigging, would go from low humidity to high constantly. Many, many fingerboards popped on desert musicians due to this. My ebony is still going strong.
Keep in mind, not only does it have to survive humidity swings, it is constantly being flexed and vibrated, and experiencing large movement when re-stringing. Not to mention the occasional ding-dong setting a 100lb tube head on your soft gig bag.
All that, and it is only glued up with titebond 2, a quality wood glue. I can only imagine how bulletproof it would be if applied with g-flex.
