- Dec 8, 2006
I did not want to hijack the "Veritas Green Compound" thread so I will post this here... I know a lot of folks like to maintain the convex edge by hand, but if anyone is interested in an inexpensive machine here is what I have put together. I purchased a $29 Harbor Freight 1x30 belt grinder and fastened it to a piece of .5 high density poly material on its back so the belt is moving away from me. Next I ordered from Lee Valley 500 grit and 1200 grit Aluminum Oxide grinding belts, 15µ (Micron) Silicon Carbide belt, and a Leather Honing belt. I use the belts in that order. If you are just touching up the edge the aluminum oxide belts can be skipped. It actually takes longer to change the belts than to work the blade. Its no KMG, but it gets the job done. My Tiger Warden has a killer edge with just the leather belt. Here is a pic of the belt grinder and also my other sharpener
