Ed Caffrey Progression II - I'm in love!
I just received my much anticipated folder from Mastersmith Ed Caffrey. To say that the knife met my very high expectations is indeed an understatement. First of all, it is much more attractive and better finished than I had imagined. Ed makes an effort to promote these knives as utility folders, very simply done in basic materials that come together to define a working folder in his mind.
The knife is built around a liner-lock frame of 15N20, features blasted black G-10 scales and a 3 1/2" blade of forged 52100. Sounds pretty drab, does it not? There were many surprises to be found after I received the knife. This is one beautiful knife for a working folder! Ed's heat coloring of the liners results in a vivid blue/purple hue that is nearly as bright as anodized Ti. As an added touch, the edges of the liners are beautifully textured which in addition to improving the looks, have the added bonus of increasing grip to a small degree. The knife uses a 3/4 length backspacer (G-10?) for strength and it looks very nice sandwiched between the colored liners. The pivot pin is also colored and nicely fileworked which is a nice touch. The Ti clip is anodized to match the liners and set up for deep pocket, tip down carry and it works very well. The blade sits perfectly centered in the handle when closed, lock up is 100% perfect and the blade is super smooth with no noticeable blade play in either direction. Folder function basically doesn't get any better than this.
The real beauty of this knife however, lies in the blade. While Ed's website proclaims him to be the "Montana Bladesmith", rest assured that this is an area where he excels. The resulting forged 52100 blade is 3 1/2" long and approx. 3/32" thick. It is fully flat ground with a very nice distal taper and convex edge with no secondary bevel. The blade also is highlited by an acid etched double temper line. Cool. The blade is topped off with dual Ti thumbstuds and while their shape did take a little while to get used to visually, they function perfectly, offering good purchase when opening and they seem impervious to snagging.
The knife performs even better than I had imagined. As one would expect, this knife cuts like a laser! The combination of a relatively thin blade, full flat grind, distal taper and lack of a secondary bevel all come together to allow the blade to ease through the cutting medium with a minimum of resistance. 1/2" rope was push cut with amazing ease. Hard Maple dowels were whittled with good bite and penetration. I personally have never used a knife so adept at cutting cardboard. When I received the knife, this was the first material I cut. Grinning from ear-to-ear, I proceeded to cut box after box, just because of the ease in which this material was handled. I actually just kept cutting until the edge was totally shot. This resulted in a pile cardboard, a dull knife and one extremely satisfied knife user :D A few swipes on my Sharpmaker followed by stropping on leather had the edge back to a razor in record time. The blade was rubbed with Ren Wax when received and has been carried daily for a week with no signs of rust (this included a weekend of hunting in the wet woods). I have absolutely no reservations about the forging or heat treating on this knife as the edge holding was very good, sharpening easy and the resulting edge very, very fine. Seems as though I had heard that Ed learned to work his 52100 from a certain Mr. Fowler whom is said to make a decent blade in his own right ;)
If you are looking for a do anything, hell for stout, car door prying tactical folder, you best look elsewhere. If you are looking for a superbly designed pocketknife that excels in cutting and slicing the material that 99% of us cut, this baby is just the ticket. The fact that this knife is the least expensive custom folder I have purchased is icing on the cake. Did I mention that I really like this knife :D
Thanks blademan, I hope you do not mind, but I think I am falling in love too (at least from the pictures and the impression you have :D).
blademan,
Thank you for the wonderful comments, I'm flattered, and very glad that you like your folder. I must admit that I fussed over the action on that folder, at first thinking it just wasn't smooth enough, and after working on it for a couple of hours, thought it came out well.
I'm also glad to hear that it has met your performance expectations! Again, thank you for your very kind words, they are very much appreciated!
Thanks for the positive replies all.
Ed,
I did not mean to babble on like that, just trying to give credit where credit is due :) I sincerely hope that you found my descriptions of both the knife and your design goals accurate. I certainly appreciate the extra effort taken to ensure that everything was perfect when it left your shop. I speak from experience when I say that I have received knives in the past in which this little extra effort would have made the difference between a very good knife and a truly great one. BTW, not much luck with that Whitetail buck :(
Ed's work is always awesome, plus he's a great guy...so I'm sure your knife-buying experience here was all around great. How many guys out there are willing to forge down 52100 for a folder? not many...
The little sperical thumb-studs are very cool looking and user friendly too.
Thanks for posting the pics! :)
Nick
Blademan,
thank-you very much...you just summarized everything in my head, only i could never have put it out there with that much sense.
i too just received a progression folder from Mr. Caffrey. mine is the modified version which is about an inch shorter than yours and i picked the wharncliffe style blade.
i too appreciate the extra effort that went into making my knife. it is absolute perfection, and i expect many years of satisfied use from it.
regards,
bill o.
If Ed would make it in some other handle material, I may have just found my dream folder. Beautiful knife, Blademan, and in my favorite steel.
That is one sweet lookin (and sounding) knife!! I am starting to branch out past stainless steel. I bought me first 52100 folder a couple of days ago, and now I think I better run over to Mr. Caffrey's site to see if he has any more!!
Thanks for sharing your photos.
Barry H
You can just tell by looking at that blade that it is made of 52100. There is something about the color that gives it away. That is a beautiful folder. Nice lines and great materials from a top notch maker.
Looks (and sounds) like the perfect "user" to me!! Thanks for the definitive description and the pictures!! Very nice of you....
"Hunters seek what they [WANT].., Seekers hunt what they [NEED]"
