EDC Alignment?
Just rec'd my EDC in 154-CM. Pretty happy with the feel and action of it although I have not tried the cutting test yet. While giving it the once over I noticed the blade sits far right while closed almost rubbing when pressure is applied to open. This is my first Camillus and it is my first framelock. Is this normal for this knife? If not, can it be adjusted by myself and how? My concern is with screwing up the lock if I use too much "persuasion" with it.
With a little tuning this knife will rock!
Thanks in advance
That was my post. I still do not have the knife aligned as well as it was when new. Better, but not "right." I spoke with Will, who was very helpful. I'll probably have Camillus check out the knife after the holidays.
With a little adjusting the blade now sits dead centre.
Sometimes it still does not look right but I have realized the framelock bar creates an optical illusion. Since it hugs one side of the blade and is shaped differently it looks not quite right. But is is right on. All is cool in EDC land and I see a Talonite version in my future.
92degrees,
Good luck with your EDC, I'm sure Camillus will look after you.
Cheers,
Gord.
