A sharpmaker and a strop go along way in keeping them sharp, I use mine when the edge starts bind, other then that needle point oil helps in keeping joints moving freely, remember a little goes along way.
You don't need a strop. Stones are superior. Get a can of compressed air to blow out dust.
Why do you say a strop is unnecessary? Does regular stop use not wildly increase the longevity of a knife?
Hey all,
Is there any maintenance you do to your EDC folders? Cleaning and lubrication? Anything like that? How often? What products do you use. Getting a couple nicer knives soon, want to make sure I properly care for them
Strops load with metal particles and you can't really clean them. They round the edge. Stones can be cleaned and they don't yield, so they don't round the edge or burnish it. Stones are superior.
Stones will cut steel each time you use them though, no? I like a strop because it will fix the edge and put the edge back to where it was. The yield of a strop allows the edge to remain undiminished.
I like leather with green compound. I scrape off compound and reapply it when it gets too dark, but I have only done that once in two years of stropping. I strop my knives daily, both to repair any micro deformations and because it is therapeutic. If you don't use much pressure, you don't really have to worry about rounding your edge over.
A Sharpmaker and a set of strops is what I use. The strops get most of the work because I don't do anything that really challenges an edge. Using loaded and bare strops allows me to straighten and repair an edge without removing much steel. I really like the balsa strops from HandAmerica. I load them with 3 micron and 1 micron diamond paste or spray. I finish up with a bare horse leather strop. Most of the time that's all my blades need.
I just got a Balsa strop & 1micron diamond spray from handamerican, gonna try it out today. When you first loaded your strop how many sprays did you use to apply the diamond spray?
Hey all,
If we're all gonna be honest, cleaning (other than wiping the blade down) and lubrication are generally unnecessary or very infrequently necessary. I've spent a fair amount of time unquestioningly breaking down my knives to clean and lubricate them and I finally stopped doing it to see if there was any performance difference. I honestly haven't noticed any. I recommend cleaning your knife if it is visibly very dirty, such as having food debris, pocket lint or mud and dirt stuck in it. Those things can potentially compromise the lock or increase wear on the pivot or blade if you get some abrasive particles in the wrong area. Even then, as others have said, soapy water and canned air do a pretty great job of cleaning and drying everything even without disassembly. As for lubrication, I honestly lube my knives about as often as I lube my door hinges and I essentially do it for the same reason. They've starting squeaking and I find it annoying. Regular lubrication is almost always only important on items that move very frequently and very fast, because then the friction builds heat which can damage all sorts of things that you don't want damaged.
