EDC = N+1
Have this (love it!)
Am considering this
Would love to afford something like this
Or this
But I have a budget that feels like this
Honestly, I'd much rather just stick with my master Hunter, but I'm a little concerned it might be too big for the office.
What suggestions have you for a small EDC that is inexpensive, looks good, works well for food prep and office chores but disappears into a belt or pocket in a way that doesn't raise alarm bells for people?
Or, any suggestions for ways to get away with wearing the master Hunter?
Hmm,
I know your budget is limited but how much are you able to spend exactly?
We can give you options depending on the $ you'd like to spend.
By the pics, I take it you would like for the suggestions to be for fixed blades?
Does it need to be a fixed blade? If not, I would suggest a Benchmade Bugout. Won't break the bank, light weight, deep carry pocket clip, disappears into the pocket.
Mora. Condor. The go-to names for "beer budget" fixed blades. Some of the Moras have handles that make them look more like kitchen knives, which may remind your co-workers of something their grandma used in the kitchen. Nostalgia is an excellent way to short-circuit that "omigosh he's got a knife!" reaction.
Svord and Kellam also make some small fixed blades. May be worth a look.
Edit: Forgot Old(e) Hickory. Also some "kitchen knife"-looking options. Or, snoop around local flea markets. Some interesting things to be found, but you need to know what you're looking for if you go that route.
I quite like the Master Hunter and have an old one in CarbonV.
Small EDC; Ill recommend Spyderco StreetBeat, MISSION Ti MPU and/or BK14.
With your budget concerns, you might want to disregard the Ti MPU.
The StreetBeat can be had in a 'lightweight' version. Not much difference in weight IIRC.
As for unobtrusive carry of the Master Hunter, I heartedly recommend sash carry with a static line.
Joe Paranee from this forum has written on the subject of this vintage carry style, which works as well today, as it did a hundred yrs ago or more.
If interested, maybe search his excellent writings and not least videoes on the subject.
After reading his posts on sash carry, I made my own Q&D sheath to experiment with the concept.
I dont have a sash carry sheath for my CS MH but just now snapped a few pics with a coffin handle bowie to demonstrate the sash carry concept.
The beauty of sash carry is, that you unobtrusively can carry far larger knives than the MH and the bowie shown here.
Also check out Mike Sastre's writings/videos on the subject of unobtrusively carring a large knife.
Anyway, on to the pic/sash carry demo.
Stage one:
Sheath goes inside the belt. It has a button, which ensures, that the sheath doesnt submarine under the belt.
You adjust the carry for your activity, driving/sitting position and/or build.
Here just one position slightly to the back of the hip bone.
The static line is attached to bottom of the sheath and goes over the top of the sheath on the outside of the belt as shown.
Goes without saying, that the length of the line or cord should be adjusted accordingly.
Stage two;
When you draw the knife, you just grip only the handle. No need to fumble with the sheath or hold it to separate knife and sheath - that is the beauty of it.
Should the fit be tight, the sheath follows the knife part way but is held to the belt by the static line.
Stage three;
Sheath simply falls free and you only need one hand to draw the knife, should you have a pesky office memo in the other hand.
If you have the time or the inclination, you just ease the knife out of the sheath and it stays put.
My sheath most often stays in the belt as its not a tight fit. This just a personal preference. The fit can be as tight as your sheath and/or belt allows.
Sash carry is a very comfortable, fast and unobtrusive way of carrying a knife.
Not having any desire to knife fight, I only use this mode, for when I legally want to carry for example this wood chopping/fire prepping bowie into the woods without alarming passers by and without listening to the inane comments.
You adjust the position of the sheath as needed and you get used to sash carry very fast.
I always recommend a Swiss Army Knife for office work. People just don't seem to freak out when they see one. I would suggest something with two blades (one for food prep, one for other then food uses) and scissors. I know the Climber has those and is $30 or so. The other choice is a traditional knife with 2 or more blades. Schrade and Boker make quite a few under $20. Again, traditionals usually don't scare people either.
If you want a fixed blade, Mora is probably your best bet.
How shoestring? I’ve seen Bradford Guardian 3’s in N690 for around $100. There’s also the LionSteel M2 in D2 steel can also be found at the same price.
Am considering this
Or this
That cold Steel pendleton mini hunter is a great knife
The Guardian 3, with its horizontal carry sheath, is pretty unobtrusive...but whether it would fly in your office would depend on the dresscode, POLICY, and attitudes of the coworkers. In an office, I would generally recommend a folder & discretion.
As far as budget friendly small fixed blades, I like the LT Wright Patriot. The standard issue belt sheath is obvious, though small...get around the obvious part by sticking it in your pocket (with either the stock sheath, or your choice of pocket sheaths)
Have you considered the Enzo Necker 70?
Also, the search them 'Neck Knives' may yield some interesting results for you, although many of them will be a 'naked' handle without scales, which I personally don't like.
If you can get away with sheath carry, or are handy with leather and willing to make your own pocket sheath, you'll have more options, such as the Buck 113.
A note on Böker knives: For the last few years, buying Böker has been like playing roulette with their QC. If you get a good one, you have an amazing knife that will give you many years of pleasure and you will wonder how on earth the knife wasn't triple the price for what you got. I've gotten a lot of lemons though. Mostly issues with fit and finish, but also one with the worst grind ever. I also suspect they messed up the HT. If you are looking at Böker knives, my advice to you would be to inspect them yourself before buying (such as in a traditional brick and mortar store).
Stage one:
Stage two;
Stage three;
OMG, this is genius! I will definitely be trying this out!
Funny thing with the CS MH, no one seems to take notice of it when I carry it traditional style on the hip... until I pull it out. Then I get the comments... which is why I haven't taken it to work.
I plan on looking into all the knives mentioned, over time.
Condors - not stocked at my local store.
Moras - I appreciate their quality, but not their aesthetic.
Enzos - nice, but also more $ than the Boker option.
Boker Rhinos - a close call, but it's an online only purchase at my local store and I kinda like having a pointy end for packaging.
SAK's - Had one close on me once. I don't see these as primary knives. Good light option vs Leatherman, but I like pliers... and locking blades.
Folders - Meh. Maybe someday. Not my jam at this point.
The Boker Rambler is $50 Canadian (CDN), so it seems to be a front runner for look/steel/price (440C, hollow grind, 5 3/8ths total size, 2 3/4" blade, black leather sheath, different enough from the CS MH in 3V).
I really don't know if a small fixed blade is going to work for me, so this particular package seems to be a good fit for what I'm after. especially since it's about as small as fixed blades seem to get with a (close to) 3" blade, and cheap... ehem, inexpensive.
When I bought the Master Hunter, I thought that would be my one knife quiver. It may still be, but having some kind of small fixed for an alternative seems reasonable, right?
I can still tell my wife I'm not a knife addict, right?
Twitch twitch...
Excuse me while I go compare metallurgy on Zknives.
Glad I could help.
Its a simple effective carry method.
If/when you get around to having a carry method fashioned, remember to post the results. Goes for the knife as well of course.
The Rambler seems a nice size and shouldnt scare (too many) people at work. I quite like the lines.
You are beginning to realize, that you have opened a Pandoras box in regards to an interest in knives. ZKnives is always a 'good' sign :D
Big fan of the Bradford Guardian 3. I've had six (IIRC) and just ordered two in the Vanadis tool steel...
I wear one in M390 every day...although lost mine in the dirt for a few hrs today when I was painting one wall of my house. Found it right away, half buried in dirt, but just made me very happy. I might have to order some G10 scales in red or orange. :)
The guardian 3 is beautiful and gets great reviews. One guy called it "the perfect edc." If only it was $50! LOL.
Yup, still leaning towards the Boker Rambler as the taste tester. I'll see about posting something up once I get sorted out.
At this point zknives makes pretty pictures.
It does make me wonder if there is a heat treatment equivalent resource? Anyone know?
