OK, I should have checked first, but I just learned I am violating the Seattle Municipal Code when I carry my spiffy new Benchmade 806D2 there (which is a problem since that is where I reside). See Seattle Municipal Code (SMC) 12A.14.010 ("Dangerous knife" means any fixed-blade knife and any other knife having a blade more than three and one-half inches (3 1/2") in length) and SMC 12A.14.080 (It is unlawful for a person knowingly to: . . . Carry concealed or unconcealed on his or her person any dangerous knife). As a result I am researching EDC Utility folders with blades under 3.5"
I really like the Axis lock, so if Benchmade would hurry up and release a mini Axis AFCK (in M2 if you please) most of my troubles would be solved (although RCW 9.41.250 says . . . Every person who shall . . . have in his possession any . . . any knife having a blade which opens, or falls, or is ejected into position . . . by an outward, downward, or centrifugal thrust or movement . . . shall be guilty of a gross misdemeanor, which could create problems for many Axis and liner lock owners and some lock back owners)
Back on topic, here are the knives that spring to mind:
Camillus EDC
Mini AFCK in M2
BM 940
BM 720 (but I don't like the blade styles)
BM 705
BM 550
Spyderco Calypso Jr (although I don't want to go much shorter than this)
Spyderco Salsa?
I really like the axis lock, but a good time tested liner lock, frame lock or lockback is fine. I prefer a flat or high saber grind (don't ask me why, but I just don't like the looks of hollow ground knives). I'd like the best steel I can get for $100. 154CM is the minimum spec.
Camillus EDC
Mini AFCK in M2
BM 940
BM 705
BM 550
Spyderco Salsa?
