Alvin Hom said:
I got my Spyderco Sharpmaker and it recommends a 40 degree edge. I've read here some members prefer 30 on all their knives. What are the benefits and trade offs of each? I assume 30 would be sharper but would lose it's edge faster.
TIA for your advice!
Well, BOTH.
Truthfully, I do about 15 degrees (30 inclusive) for the initial bevel, then I polish that bevel and make it shaving sharp for good measure.
THEN
I hit the edge with a sharpie (So I can see what's going on) and put the secondary bevel on at about 20 degrees (40 inclusive). I shape the second bevel until about 1/4 to 1/2 the witdh of the first bevel sharpie is gone, then I hone to shave.
THEN
I either hone it with an ultrafine stone at 20+ degrees or strop to get rid of the burr.
Time consuming yes, but after I do the initial bevel, I can do 20 degree touch ups for a very long time.
(Sharpie ink comes off with a little alcohol)
Sorry to give you such an unhelpful answer.. generally the thinner the better if you are slicing, and a little thicker if it will see abuse (cleaving bone etc).
Edit:
Alvin Hom said:
... I assume 30 would be sharper but would lose it's edge faster.
"Sharper has little to do with the angle.. .any angle can have a shaving sharp edge, But the thinner the bevel (and blade), the easier the blade can go through material and the smoother the cut. (This is why Victorinox blades slice so well, even though the steel is mediocre.)
It is questionable whether it would wear faster, less resistance at 30 deg, but more behind the edge at 40. It probably depends more on how tough the stuff is that you cut.
