edge angle for busse combat
Hope I'm in the right part of the forum. New to the Busse forum....
I am sending a Busse Combet into Busse for a resharpen. Funny, I'm a knife collector and almost always sharpen my own blades on my Edge Pro Prfessional, great sharpener. There has always been something about INFI steel that throws me for a loop though when I put a stone to it, it seems to feel both hard and soft at the same time...
Anyways,,, the blade that I am sending into Busse is a Combat that is almost .3" wide at the spine and tang, 13" overall with a blade that's 6.5" long. It is at the 'standard' busse flat bevel angle (I've herd they usually do 40 degrees, 20+20). I don't think of it as a chopper though, I have longer knives and real chopping tools for chopping.
What do you guys think the most acute angle is that I should ask for.
It's such a great knife (this is it's first sharpening besides burr fixing on a steel and stropping, which has kept it shaving sharp till now, but is now in need of some attention. I want an acute edge on it. I used it for skinning once on a hunting trip (deer, white tail), and it was a little big but worked quite well. At the time though, I was wishing the blade was a little thinner.
Thanks for any advise from you Busse vets. I've been laid off, so I don't think a Busse at a more appropriate skinning length and thickness is in the works at the moment, so for now, it would be great if I can take this blade to my next hunting trip and skin at the speed of sound!, unless any of you guys out there have a short Busse blade that you just want to get rid of, to a good cause (I usually hit and kill what I aim at!).
Thanks,
Dan
:rolleyes:But, while you're waiting to get there ...
Throw a PM to Ban or perhaps Randucci. They've both done quite a bit of hands-on work with INFI and could give the best answers.
Do make sure to explain precisely WHAT you want to do with your INFI. The right answer to your question depends on your use ... which I imagine (from your description) is as a basic hunting knife.
The trick, if there is such a thing, with INFI is simply not to get too acute an angle (and therefore too thin an edge), which promotes edge deformation.
