- Mar 7, 2010
Is there a "standard" or recommended edge angle for folders? Where can I read more about this? I would like to know what is the difference between 15, 20, 25, etc. degress. Thanks.
20 per side is the best all around angle, leaves good support for harder cutting.
15 Per side is better for fine slicing, but the edge isn't supported as well for harder cutting.
I wouldn't go above 20 or 21.
Some good advice here so far. My default angle is 15/side for EDC, 10/side for kitchen knives with premium steel (VG-10). Some of my S90V EDC blades are also at 10/side but that's an exception to the rule. Type of steel and intended use are the two things to consider. If I was using my knives hard, 20/side or 15/side with a micro bevel of 20/side would be my choice.
I am able to quickly touch up or sharpen a knife so long term edge retention is not a big factor. The knife will wear faster but I make that up in numbers.![]()
Kenny, no arguments from me on "edge holding," I just call it toughness. For 95% (or even less) of the knives out there, a very thin edge is not practical. And for something like S30V, I don't go below 30 degrees inclusive.
My 20 degrees kitchen knives rarely see bone and in our kitchen, it's mostly chopping/slicing tasks. And S90V is something quite special. It's tough even when thinly ground but I wouldn't try that with something else.
All opinels i have did not even have an edge when i got them, most certainly not a convex one. They do get wicked sharp however. But that can also be because of the thinnes of the blade..I don't believe you can be definitive on this as there is too much variation - thickness/profile/steel/heat-treat + intended use(s). Having a multiple bladed folder as suggested in some of the replies is a great option
One of the reasons why Opinel have a reputation for being such great slicers is the combination of thin blade and convex edge. I take a leaf from that book and usually convex or micro-convex the edge on all my EDC folders so the actual angle becomes kinda irrelevant. I strive for the finest convex edge that will hold reliably and this will vary markedly from knife to knife depending on the steel and heat treat.
:thumbup: well saidThere is no standard. The angle should be made to meet the requirements of application and the steel from which the blade is made. Too acute and the edge fails. Too obtuse and you waste some of the edge holding ability of the steel. My advice is to start on the acute side at a point where the edge folds. Then make it more obtuse with subsequent sharpenings until the edge no longer fails. That's the correct angle for that application and that steel.
