- Oct 21, 2010
So as I'm digging around and putting together the pieces as it were...
I got an EdgePro and started sharpening anything in reach.
One of the things I've seen mentioned and that I've tried that seems to work, particularly with my older, crappier (if I had to guess, most are 440's as they are unmarked) steel blades is a double bevel.
I profiled the main bevel 'low' somewhere around 15 degrees roughly and polished it out to 1000 grit. This thins the edge profile obviously. I noticed on the crappier blades that this doesn't always cut all that great so I then put a 1000 grit secondary bevel at a quite a bit higher angle, say at least 25-30 degrees. I noticed on an older Gerber Magnum LST that it really seemed to improve it vastly.
Did I just do a better job on the secondary bevel vs the first try or does this actually make sense where the steeper bevel supports the softer/cheaper steel better than just a single low angle bevel? From what I read, that seems to be why it is working, but just doing a head check on it.
I did the same on a few kitchen knives and a CRKT ringed razel with similar results. The initial low profile bevel wasn't as good until I put the secondary on it.
With my Benchmade 741 I just matched the factory high angle bevel, I'd estimate has to be 25+ and it was an instant razor with just enough work to polish out the very rough factory edge. I did it this way because this one already has a thin blade profile. This one has decent steel too, I could actually feel the difference when sharpening it.
This is all in context for my pocket folders, not meant for chopping, primarily slicing with no real impact on them.
