I've got a knife that picked up some edge deflection. Theres a small portion of the edge that looks like it was hit from the side creating a sort of s-curve while looking at the edge. Is there a way to fix this without sharpening it out?
Not really, it's hard to see in person much less on camera.Can you show us a photo??
That's kinda what I figured, thanks.If I understand correctly you are talking about a wave in the blade that is past the sharpened edge and is slightly into the main bevel. If that is correct you should probably just let it be, I very(very) carefully attempted to correct a similar deformation and snapped a 1/4" deep half moon out of the blade.
I actually missed his whole post, but this is the best pic I could get. I think I'm just not gonna worry about it.As Obsessed said, it really depends on the size of the deflection. A macro shot should show it clearly. Describing it as "a small portion of the edge" isn't specific enough a description. Can you measure it? At least the length?
If it's really small -- maybe a mm or two and doesn't extend more than half way up the bevel -- you can use one of the methods that Obsessed mentioned. If it's a larger half moon a quarter inch deep like Brain said, the edge is too damaged. You might be able to find a workaround to get by, but you'd be better off with a new blade.
Thanks everyone, I'll try stropping and steeling it out. If that doesn't work, I'm sure it'll be fine. Worst case I know the blacksmith will fix it if it gets worse.
