Edge Degradation from oxidation on non-stainless
JBoone
Just wondering what everybody's experience is here.
I have not tried to do any testing by any means, but it feels like I can tell a difference between the sharpness of stainless and non-stainless after sitting several months. I usually have to strop the non-stainless to bring it back to "sharp" if I have not used in a while.
Seems to make sense. Even if I oil my non-stainless blades lightly, the edge is often exposed after cutting and therefore more prone to oxidation. Though not readily apparent (visually) to me, it seems to effects the sharpness.
Just was curious as to others experience.
My oldest carbon steel (O1) is 14 years old. It's fine. I have a few others that are about a decade old: 5160, O1, and A2. They're fine. I do use and sharpen my CS knives and inspect them from time to time. I haven't had any issues.
CS is subject to oxidation and corrosion, so it's wise to inspect CS every once in a while, at a minimum. It's a non issue if you use your knives and maintain them.
What shiny edges said, it happens if not used for a while and exposed to moist air, but I have had carbon steel knives stored for years in a basement that is rather damp, and even though they had visible surface rust on the blades, the edges were still sharp enough to shave arm hair and certainly still usable for edc.
Thanks for the feedback. I am thinking that I did not put these away as sharp as I thought I did. I could see if a knife was visibly rusted, etc. but not the case with the ones that I am talking about.
Didn't consciously "Put them away" per say, just have too many EDCs and it can be some time before some of these are carried.
Grew up right on a salty laguna in Texas. Corrosion can be extreme beyond belief.
South Texas is pretty damned humid, and I use a shi!tload of 1095.
With that, I've noticed ZERO edge degradation on my knives.
Your mileage may vary.
