- May 18, 1999
I hope I can state this in a way to make it understood the answer I am looking for.
I have seen the term "edge geometry" since I was a very young lad first interested in knives and I can't remember when I wasn't.
All of the edges will have a final edge bevel of 15* for comparison.
To get to the point, say you take a piece of steel that is 1 1/4" wide and 5/16" thick and put a flat grind on it. Then you take a piece that's the same width, but only 3/16" thick and put a flat grind on it.
Of course the thinner blade is going to cut better because there's not all that steel trying to get through the narrow cut the edge has made.
If you put a high hollow grind on the thicker blade there by thinning the edge that much more is it really going to have a better edge geometry than the flat ground blade? I realize that hollow grind is going to probably cut better at the beginning, but how will it perform when it gets the the thick spine?
Then the convex grind is going to be an entirely different application using the same dimensions or is it?
It's pretty much a given I think that a thinner blade with a comparable grind is going to cut better than a thicker blade.
So is it actually "edge geometry" or "blade geometry?"
And what really does a good "edge geometry" consist of and is it related to the overall "blade geometry?"
That's it for now. I have some more questions related to this, but don't want to make it any longer than I already have.
Thanks.
>>>>---¥vsa---->®
"I would rather have a bottle in front of me than a frontal lobotomy."
........unknown, to me anyway........
Khukuri FAQ
Himalayan Imports Website
Thanks.
>>>>---¥vsa---->®
Khukuri FAQ
