- Jan 2, 2011
So I have been doing research on grinds and using a grinder to preform the grinds and I came across the thread about edge geometry, it was a very good read:
http://www.bladeforums.com/forums/showthread.php/838481-Edge-geometry
Lets talk about the specifics of the flat grind:
1) If you have a 4" blade
2) Blade width of ~1.5"
3) Drop point that is just around .5" drop from spine,
4) 5/32" thickness
5) You have a "perfect" flat grind that is somewhere in the number of 3.25 degrees,
6) You have decided not to break the spine and leave 1/8" left on the flat of the knife to the spine
If you grind your knives and just drag your blade across the belt without putting any pressure on the tip, the thickness of the tip located at the 1" mark from the edge of the blade would be ~.1138". (I sat down and did the math and this would depend on perfect angle and the width and thickness of the material)
That would lead me to believe that pressure must be applied around the tip area to create a distal taper. The "correct" thickness of the tip around the distal taper would probably depend of the intended use of the knife, type of steel, shape, etc.
What do you guys think about when you make your knives and are doing the distal taper?
4) 5/32" thickness
