I hope this makes sense like it does in my head when I say it
Currently I sharpen my knife at 19 degrees per side using the Work sharp angle adjust since this angle matches what came fron the factory. I am looking at a sharpmaker to touch up the knife when needed. My question is if I use the 20 degree setting will it be enough of a difference to create the micro bevel? This is typically what these are for correct?
Second part is if I sharpen at 20 on the precision adjust I assume I can still use the 20 degree setting on the sharp maker to maintain right?
I really hope this makes sense
