- Jan 10, 2010
I've been playing around with stock removal on 0.095 15n20 making bushcrafters and other hard using type knives. So I've started upping my ante on testing because I want to provide bushcrafters and survivalists with the best edge I can produce. So I recently made a big chopper with the 15n20 and did a little test where I did some hard cutting on a frozen red oak knot (it was 10 degrees out
)... and it still cut paper as well as before the cutting.. and I really gave it man... almost 2 minutes of wood removal on wood as hard as nails. The 15n20 was tempered at 400.. not sure what that Rockwells to. I'm using a convex edge that is very thin.. thinner than any camp chopper I've ever used. I was impressed with how it handled that red oak.. although I suppose there are better evaluations than slicing paper.
but today I tried another blade.. heat treated the same, same edge grind.. but this time I did a lot of batoning.. splitting and hacking into that same gnarly piece of frozen oak. This time it wanted to tear the paper a bit... it still cut, but not as efficiently..and it didn't cut my rope at all (before it was slicing it easy as pie).
So... was the batoning on such hard wood just too much for any blade or steel? I mean.. It didn't fail or anything... no crumpling, nicks, cracks, roll overs, etc. It just got a bit dull.
Anyway.. my point here is this... what should be my expectations after almost a solid 2 minutes of vicious chopping on very hard wood? One thing that occurred to me here... when I did the first test I hand chopped.. which, I think, distributed the wear to many parts of the blade. But the batoning concentrated it to just the middle area of the blade.. which is where it got dull.
So... again... what should I expect if my 15n20 was heat treated perfectly? Am I asking too much?
