Can't you cut and tape different grits of sandpaper to the stone/blank? I don't have the Edgepro, so I can't tell you if it will work, but I don't see any reason why it won't.
You can. After all that's exactly what their polishing tape is. Adhesive tape on the blank. They sell glass blanks too.Can't you cut and tape different grits of sandpaper to the stone/blank?
Great post Gator thanks for the help. I appreciate your info on the stone grits too. The Sharpmaker is already gone yesterday and I'll call Edge today and adjust my order accordingly to include the more coarse stones and maybe some polishing tape.Wow. I've ditched my sharpmaker back then because of the edge pro apex. 600 grit is definitely not enough, it's too smooth. Edge pro grits are not ISO grits BTW.
For major metal removal you need 110, and then 220. 320 and 600 for finer edges. Either way, you'll need all 4 stones and if you are into sharpening ceramics then I'd buy their diamond stones too.
Plus, if you want very nice polished edges, get the polishing tape too. That's around 6000 grit Japanese waterstone. Pretty high level of edge sharpness if you ask me.
Especially for the beginners Edge Pro is much better choice. You get to hold steady angle and sharpen very fast. Yes,edge pro has its quirks and learning curve, but that is nothing compared to Sharpmaker. I've seen so many people disappointed and disheartened by it. Not because Sharpmaker doesn't work, absolutely not. It works, but it's not that simple to use for the beginner, and unless you get it with diamond rods it's pretty much impossible to get anything serious done with ceramic stones.
Even when you are proficient with sharpening, edge pro still has its uses. I still use it every once in a while, especially when time is important and I don't need to sharpen convex edges. Or when I need to remove lots of metal fast.
:thumbup: Edge pro is more versatile than just symmetry. You can do perfect asymmetrical edges with it no probs. Compound or double bevels (like sharpmaker can do), except angles will be chosen by you, not fixed. Glad, if I could helptrue symmetrical edge. A good polished edge from an Edge product is a thing of beauty in symmetry.
Also, don't dump the sharpmaker - that is much easier to set up, and will let you sharpen certain knives easier than others.
