Hi guys,
I have the Edge pro and I can get decent results with it. I bought shapton pro stones which are awesome but with finer stones my problem is more visible. I use the drill stop collar and angle cube. For example I set the bevel with 320 shapton stone, do the trick with the collar and start sharpening with the 600 stock stone - I can see the angle is wrong because the stone is hitting +- 1/2 of the bevel - so I have to adjust it manually which sucks. The frustrating part is that before changing the stone the angle cube measured 14° and after the same. The blade is always put into the same position due to the plastic shim. Any idea what I could be doing wrong?
Thanks!
Thanks!
