spyken
- Apr 29, 2002
I have had my edge pro for quite awhile now. I have a sharpmaker too. Usually I use the edge pro to reprofile, then touch up with the sharpie. The one reason I don't use my edge pro more often is that I find it difficult:
(1) to get the correct angle which corresponds with the sharpmaker (for eg. 15 degrees on the edge pro is not the same as the 15 degrees on the sharpmaker)
(2) I can't seem to sharpen the area near the ricasso well (always very difficult for me to get a burr there - the stones don't seem to be touching that area)
(3) I also don't know how/where to place my folders (all under 4 inch) or fixed blades which have distal tapers or sabre grinds on the table.
Do I lay the flat portion of the blade so that it contacts 100% with the table (this means the edge portion does not contact with the edge of the table)? Or do I lean the blade downwards so that the edge of table contacts with the hollow-ground portion/edge portion of the blade? On some knives it is really difficult to make sure that the hollow ground portion of the blade contacts with the table cos of a large flat ricasso area? Which ones gives the proper edge angle?
Does anyone understand my problem and can help?
I can of course get a shaving sharp edge with the edge pro, but have difficult sharpening on the left side of the blade (my movements are not as co-ordinated as my right side).
I know this may come as sacriligeous (spelling?) to all the edge pro fanatics out there. Perhaps I should email Ben Dale about this trouble I have? I don't want to return the edge pro as I spent quite a bit on it and haven't yet recouped my investment.
I find the sharpmaker more idiot proof for a technically challenged person like me, so have just ordered the diamond sleeves as my blade(s) are in VG10.
