I'm thinking about getting my first edge pro and I'm wondering if it holds the angle for me or do I need to know how to keep the angle myself?
The EdgePro will hold any angle that you set, and hold it at the EXACT angle. No slippage or free play as you get with the DMT Aligner. If you keep careful records when you sharpen, you'll be able to re-set the EdgePro to the same EXACT angle every time you sharpen a particular blade. It's up to you to keep the records. I usually forget to do so.
Also I want to be able to strop with it , rebevel and everything in between so which one should I get? I don't want to leave anything out I will need to get my blades hair whittling sharp.
The Apex works just as well as the Pro. The difference is in how it sits on the work shop table. (The Pro will also sharpen scissors. I don't think I've ever needed sharper scissors. I still use the ones with the rounded tips. I never, ever run with them!
) When you order your EdgePro, get the full stone set and also an extra 120 grit stone. That's the only one that seems to noticeably wear out. Also order extra polishing tapes and 3-4 extra stone blanks. You can mount your DMT stones on the blanks for diamond re-profiling should you really need to, and you can mount leather for stropping. (You'll probably need to put on 2-3 thicknesses of leather to match the thickness of a stone and get the same angles.)
Any other advice or reccomendations are welcome.
Use plenty of water. Add a squirt of water to wash away metal dust every few minutes. Don't worry about washing away the stone slurry. That forms very quickly. This washing is especially important as you get to the higher grit stones. With them, I wash after every 5-10 strokes (or less) of the stone. I keep shop towels on the table on either side of the EdgePro. I use a lot of water.
When you set up the platform and the spine support, only have the minimum edge exposed over the end of the platform. Less is better.
Don't bear down on the stone arm. You don't need much pressure at all. Just the weight of your hand pressing it down to the blade is more than enough. Use even less pressure as you move up the grits. By the time you've reached the polishing tapes the only pressure should be from the weight of the stone arm itself, with NO pressure from you at all.
Be VERY SURE that you are keeping the stone moving 90° to the edge. If the blade curves, move the blade on the platform so the stone is still moving at 90 degrees.
Work one side until you raise a burr along the entire edge before you switch to the other side. Then raise a full burr with that side before moving to the next higher grit stone. Be sure that you actually are creating a burr on that second side, not just pushing over the first burr. When I'm doing a knife, I create that first burr, flip the knife and create a second burr, then I do it AGAIN, but with only a very teeny tiny burr on each side just to be sure. After a while, you can
feel when a burr is beginning to form and stop there, saving some metal. Then move to the next stone and do it all again. As you use finer grits, you will be making much smaller burrs. None at all when you reach the polishing tape stages.
Some people like to put a strip of masking tape on the sides of the blade to protect it from scratches. If you're working on a 'special knife' and don't want to see any imperfections on the sides, tape them before you start to sharpen. Personally, I don't do this with my knives, but I do rinse the blade platform with a squirt of water from time to time.
I use a back-and-forth motion with the stones, but stroke only one way with the polishing tapes and leather strop - spine to edge for them. With the polishing tapes I wash them (and the blade) with
every stroke. For stropping, I use diamond compound followed by CrO2 compound followed by a bare leather strop, all at the same angles that the edge was sharpened to.
Some folks want an ultra fine scratch pattern finish for a shaving sharp knife. I want the finished edge to be so mirror-perfect I can use IT for my shaving mirror! You can get that in just a few minutes with an EdgePro. So mirror perfect that you can read a newspaper in the reflection... if you can read backwards.
I'm using a DMT Aligner kit now and I'm doing ok with it for the most part.
Thanks.
If you can use a DMT Aligner, you'll have no problems with an EdgePro. You WILL get a better edge. The DMT's stone guide rod goes through a large hole allowing quite a bit of freeplay in the guide angle. There is absolutely none with the EdgePro. The angle you set is the angle you get. Enjoy your new sharpening device, and know that there is simply nothing better on the market today for hand sharpening any knife you have!
Stitchawl
