Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
I've had the Edge Pro for a little while now, although I've not always been home to be able to use it, but getting better at it.
I recently picked up a couple of folders that had small coping blades that needed sharpening, quite narrow blades. I have the 1/2" stones but was able to sharpen with the regular sized ones.
But the tip I wanted to make note of is the back support where the knife's spine rests against, even with the white plastic removed, the plate is still kinda thick and the stones could rub against it before reaching the blade.
So, I cut some tongue depressor type sticks, I have them for gluing leather, and made one so it was just about as wide as the deck.
Then placing the stick against the metal slider, and the knife's spine against the stick, I moved both until the edge was just up to the end of the deck.
Then I tightened down the metal slider and taped down the stick in front of that.
Worked great, although with water the tape does come up too quickly, can't find strong enough adhesive that will also pull off too, will keep looking for that.
anyone else with tips please add them to this thread,
G2
G2
