- Oct 9, 1998
Hey guys, I've noticed that on my Edge Pro Apex with the upgrades, that the polishing tape gets cut into and stuff and it gets all potholed and it will scratch the edge bevel leaving an inconsistant mirror finish.
I've just experimented with some stuff and it works very well. If you cover the blank with three layers of masking tape, then use a white rouge bar on the last layer, then use that in a reverse motion in the rig, it will polish the edge but not scratch the edge bevel. Remove the top layer after you are done with the white rouge, and charge the second layer with red rouge and use that to polish. The bottom layer remains there as a safety so the edge doesn't scrape against the blank if the top two layers are cut. Remember, backwards motion like you were stropping. Do all this after you finish getting a good solid finish with the 600-grit water stone. I'm sure other polishing compounds could be used, but I don't have any others. Anyone want to try this and see how the other compounds work?
