what profile do you guys like? and why?
It depends on how thick the stock is...
The real question is, how do you get a nice radius in your grind termination when shooting for a quite high grind line.(plunge line) Do you want a plunge line to go straight up? Angled up forward but straight? Radiused?
Should a grind line follow the belly and curve with it, like it? Should it be flat like a ruler to the tip or should it angle up or down no matter the belly?
OP: Just for my own understanding, you say "edge grind" so when you want to or need to resharpen the edge and you want to maintain the original angle, you would have to pretty much lay the edge grind flat against the sharpening stone? So for #4, with every resharpening, you're even thinning out the whole blade?
ETA:
re: your statement for Type 1: "This edge is very common in production knifes for a simple reason. It minimizes stock reduction, ergo material cost."
I don't see how #1 is associated is minimizing material cost if that is what you mean. You already paid for the material. You're not going to save money by reducing the amount of stock you remove. What you may save is the machine or labor cost to remove incremental material above the minimum. As a matter of fact, if there is any salvage value in the material removed, minimizing material costs may be more associated with Type 4.
If you're saying you can save on material cost with Type 1 because you can start with thinner stock, then you're not using a fair comparison. A fair comparison would dictate that all other attributes of comparative samples are the same except for the attribute you are analyzing which, in this case, is the edge profile.
Per the first part the profile has little to nothing to do with the grind... most #4s are primary flat grinds with some kkind of secondary edge... not necessarily a true scandi
For the second..
As a maker material is not just the original bar stock to me...
... should have been more specific... profile 1 Saves on end mills, belts, and most definitely labor. .. I consider those all "materials"
For the first part, thank you for clarifying. In that case, for the most part, I think it's simply aesthetics besides the obvious trade-off between mass and ability to slice. One can take the extreme cases for initial blank thickness from being very thin and being very thick and compare the profiles within the same thickness. On the other hand, one can make a case that #1 profile with an initial thin blank would have better slicing ability than a #4 profile made from an initially thicker stock. Hence, one can say one can arrive at the desired slicing / minimal stress risers condition by also varying the initial thickness. If one can arrive at a target slicing / minimal stress riser condition by mixing and matching variables such as initial thickness, edge profile, (not to mention steel make up), then I think it supports my belief that it comes down to aesthetics.
For the second part, as a manufacturing professional, the standard as you know is that material is divided into direct and indirect material. And when people talk about "material," the consensus is they are talking about direct material - the material that is part of the product. To refer to indirect material as simply "material," the context ought to be laid beforehand which, in this case, it was not.
Bad termanology makes this thread confusing.
Sooo...
1) VERY low saber
2) Mid/nominal saber
3) High saber / full-grind
4) Full Flat Grind.
