For the record, I've done 3 blades and about 6 cutting tools out of O1 that I've fully hardened by pure dumb luck it seems.
However, last night I was working on a blade I've been goofing with (it's really goofy, too). 1/8"x1x~9" long hunter-type with a funky handle. Pre warmed it in my mini-foundry. Then heated it to the point I could see shadows dancing, which is what I look for, cut the flames, grabbed it with my tongs, and went to do an edge quench of it (my first attempt). I'm using about a gallon of vegetable oil, since i got it cheap for quenchant, and had heated it beforehand. I held the edge in the oil for about thirty seconds, then dunked the blade fully into the oil. swished in a linear cutting motion under the oil, then withdrew, and inside to the toaster oven (wife's away
). Tempered at 400 for an hour, then let it sit overnight.
Two things happened that I haven't had happen before. One, the spine (but not the edge) and the last inch of the handle warped. Not very much, say 1/32, but still very noticable to me. Second, as I was testing the hardening/tempering, first with the file test (skated nicely off the edge, bit into the handle area). Then I applied moderate bending pressure with my hands to see if it would snap. It didn't. instead it made a nice 30 degree bend.
I think I'm missing something im my process and am looking to you all to enlighten me as to what it is.
A, how can I avoid the curvature?
B, for edge quenching is there a "better" way to do it?
C, anything else I should be thinking about when I try this?
Thanks,
An inexperienced wannabe.
Thanks,
