- Feb 11, 2014
So you have a new knife and it came shaving sharp from the factory. my question is what are the benefits of refining that edge even more?
^^ this is just untrue. Honing is literally sharpening. Saying you shouldn't hone a blade because you might do it wrong doesn't stand to reason. Same thing with stropping; if you know what you're doing and have good technique/proper material for the job then its a fruitful and elegant maintenance strategy. If you don't know how, you'll round off your apex and feel like a twit.
There are considerations about what substrate/abrasives are best for different blade steels, but a wholesale writing off of stropping or sharpening is silly.
:thumbup:
Wish I could add more to that, but honestly you hit about everything I was going to say and than some.
:thumbup:
I concur. That sums it all up very nicely.
The only way stropping can/will degrade an edge is, if it's done with poor technique (angle, pressure) or without giving thought to what materials (substrate, abrasives used) best contribute to what the edge actually needs and what the steel will best respond to. This is exactly the same criteria that'll make the most difference in creating the edge in the first place, BTW.
David
Sorry i take it back. like i said I've read it somewhere and it's been a long time. my curiosity made me look for it. here's what Cliff said.
in general I would not recommend stropping because it tends to be used as a crutch and tends to degrade the stone sharpening.
If I was to strop then I would want a very hard abrasive on a very hard medium and use it very lightly to prevent from degrading the edge.
Diamonds and CBN are both decent stropping media.
The nice thing about the sprays is that you can just spray them on newsprint, use that until it gets loaded or just dusty and then just spray another sheet.
Cliff says a lot of things, most of them controversial...
