- Mar 15, 2007
Hello guys,
After the great discussion on the thread @Masibu started about edges dulling too fast, and the beautiful information provided for our friend from down under @wootzblade about CATRA tests, and their extrapolation to edge retention.
I’ve been thinking and these are some ideas I took:
- most factory grinds are way too thick and the same happens with the sharpening angles
- “super steels” don’t show much improvement in edge retention over low alloyed steels if you don’t take the angle way lower
- if you take the angle low (less 25° inclusive) on those high alloy steels you could start having issues with edge stability including chipping due to high hardness and brittleness
- the low grind-ability of those types of steels makes you think over twice when facing a task prone to provoke edge chipping (like cutting a steak over a ceramic plate)
- contrary to the popular belief acute angles improve edge holding when wear resistance mostly is concern.
What I take from those ideas is a reaffirmation on my believes that a simple carbon steel with a thin grind and a sharpening angle of 25-30° inclusive is the best steel for my needs in an EDC blade
Also that super steels excel at repetitive cutting chores when edge stability is a minor issue but you have to take them way lower that it’s often recommended.
To end this large post and begin the discussion I’ll throw a question
How do super steels hold up in field dressing and butchering game? Last time with some 440c and S30V on a 140 pounds wild boar(really tough skin and hair and full of dirt,here in Spain at least) I had to sharpen two times each indifferently of steel metallurgy
I know that people swear by Phil Wilson work on that scenario.
What do you guys think about both EDC and hunting with super steels?
