I had a long talk with someone that explained it something like this..... "You don't get much work hardening from sharpening and use, that all happens when the steel is compressed. When rolled is when H1 becomes hard from work hardening, it takes tons of force to compress the metal and cause the hardening." Then why such the difference in edge retention between plain edge and serrated edge? "Because a work hardened metal is only hard at the surface while the inner metal is softer. When ground for a plain edge the apex of the cutting edge ends up in the softer area of the metal while a off-set asymmetric serrated edge puts the apex of the cutting edge further into the "hardened metal" increasing the performance of the alloy."
So given that info I personally would only pick the serrated edge H1 or if it was a option a true chisel grind.
Hmm, does that mean that a fully serrated blade is "wider" than a plain edge? Also, I kind of got two different definitions on work hardening and precipitation hardening. Work hardening which hardens the material through deformation, and precipitation or "age" hardening was described as heating the steel to about 400-700 deg C and holding it there for several hours, which basically sounds like the reverse effect of tempering to me, and seems similar to case hardening. The case of the latter would explain why the spine and edge seem to read at the same hardness(Rc 58), while the side of the blade seems to scratch easier than any other steel I've ever used.
Still, official word seems confusing:
TazKristi said:
H1 is a precipitation-hardened alloy. And yes, it is also work-hardened. Meaning that anything that you do that causes heat through friction will harden the steel further; it’s also important to note that tests have shown that it does not become brittle. The work-hardened properties of H1 have been proven by analysis independently performed by Crucible Specialty Metals. It is this that explains why an H1 blade with a SpyderEdge has better edge retention than it's PlainEdge counterpart. In the end, the analysis from Crucible found the Rc at the spine was 58, however at the edge it had increased in both the PlainEdge (to 65 Rc) and the SpyderEdge (to 68 Rc).
The Salt Series knives are being made and promoted to a market where corrosion resistance is important.
So, is H1 possibly just another flavor-of-the-month? Possibly, but hype can only go so far.
Kristi
Tom Krein said he didn't know anything regarding the work hardening properties, though he did confirm that the reason why the blades are hollow ground is because of warping issues. Some have mentioned that warpage might contribute to the work hardening, though it's hard to say for sure.
Another theory is that there IS some minor work hardening going on during sharpening. Now typical sharpening shouldn't have any major contributions, but when you consider what actually happens when you raise a burr on one side and then move it to the other, that weakened piece of metal is constantly being deformed as you move the burr from side to side. Can't say for sure what significant effect it would ultimately have, though I feel sure that this phenomena isn't solely restricted to H1 steel, and that all blade steels will be work hardened to some minor degree.
In any case, I don't think anything definitive can be said without a series of Rockwell hardness tests. Though I feel this information would be worth finding out, mostly because if the precipitation hardening process is mostly why the SE version is that much harder, it would imply that the plain edged H1 knives would actually get
softer with repeated sharpening.
