Cliff Stamp
BANNED
- Oct 5, 1998
Quite some time ago there was a thread about cutting ability and edge retention of serrated blades, circa 1998, Mike Turber argued for serrated blades on cardboard from exerience cutting upon a lot of boxes redoing packages. Steve Harvey countered that a straight edged Boye knife would cut cardboard very well for a very long time.
Steve was the first person to point out that serrated vs plain edge comparisons ignored that the straight or plain edges are ground at twice the angles of serrated blades and some get as much as three times as obtuse, this makes for a massive difference in cutting ability and Steve was also not taken in by the myth of lower angles equals less edge retention.
I recall thinking it would be a good idea to compare the two with the same steel sharpened to similar angles. For various reasons I never got around to it, once of which being that it takes a lot of material to actually blunt serrated edges, and the second being that I usually don't buy them so those two conditions are rarely met simultaneously.
However recently I had a bunch of used carpet, and a Cara Cara which had both a straight and serrated section ground at near identical angles. I first checked the consistency of the carpet by using another knife to do five sample runs over random sections with rounds of 100 and 275 cuts, the performance was consistent to 5-10%.
The major sources of variance was the initial sharpness, I was freehand honing the blades for various reasons. Even just a hint of a burr totally scuttled edge retention, making a S30V blade worse than SAK. The edge retention is optimal with a blazing sharp edge which is well above shaving, no surprise, but the magnitude of the effect was enlightening.
The Cara Cara was used for three rounds of cutting. The sharpness was checked by slicing 1/4" poly under a 10 lbs load, the greater the edge length required to make a cut the lower the performance. The knife was also checked with steeling to see the effect of wear vs deformation plus examined under low mag (10x) to check visually directly.
In short, the plain edge section was comparable to a Dozier K2 and UK Pen knife in S30V, careful measurement or a very discriminating hand would be required to tell them apart (10-20% different). However the serrated section was in another class. After 275 cuts the Cara Cara's serrated section was sharper than the K2 and Pen after 100 cuts, more than a 200% improvement.
For sharpening, a small diamond rod was used to just work inbetween the scallops which were touched up with the medium and fine sharpmaker rods, then a light pass with a dowel with CrO. Total time was just a couple of minutes. The K2 was sharpened in similar time, freehand with a 200 grit SiC stone and diamond plates, fine and then x-fine then CrO on leather.
It should be noted though that while the serrated section was under the same vertial load as the plain edge knives during the poly cutting, it was harder to pull through the cord. While the others would do this easily, in fact if you just tipped them gravity would do it even on a light angle (10-20 degrees), the serrated section grabbed into the cord and required much more force.
However the mechanics of the body allow much more force to be applied on a pull with the arms than a straight push down, you can easily use your back and hips to pull directly, but pushing down is often not as easy to do depending on body position, thus even though the serrated blade requires more force in that way, it is largely irrelevant as it is easy to supply and thus an very efficient trade.
In short, the serrated section of the Cara Cara vastly outperformed the straight edge portion, and even allowed the blade to actually out cut other knives with more wear resistant and/or harder blades.
-Cliff
-Cliff
