Cliff Stamp
BANNED
- Oct 5, 1998
Details on the knives :
Coyote Meadow, CPM-10V (62.5 HRC / actually measured), full deep cryo, ground and heat treated by Wilson.
South Fork, S30V (60 HRC / actually measured), full deep cryo, ground and heat treated by Wilson.
MEUK, 52100, (57/59 HRC on edge), no cold treatment, forged and heat treated by Caffrey, ground by Blade, reground (full height) by Caffrey.
Point Guard (54/56 HRC), no details on hardening, CRK&T.
The blades were used to slice 30 cm (one foot) sections of 1/4" double layered cardboard, against the ridges through 3 cm of edge (just over an inch), on a draw with the edges set at 7-9 degrees per side, no micro-bevel, freehand.The sharpening process in detail :
-shape edge with 200 SiC
-refine with 800 AO
-deburr and reset with 600 DMT
-clean with 3 passes per side on plain leather
-clean with 3 passes per side on CrO/AO loaded leather
-clean on newsprint on leather
The edges were checked under 10x mag to examine burrs, could shave easily on both sides, usually catch hair above the skin, and push cut newsprint at more than an inch where it was being held. All cardboard cutting was done on identical boxes (random sampling through the boxes), and repeated five times with each blade, complete sharpening each time.
What isn't surprising is the order of the blades in regards to how they performed on the cardboard, the Coyote Meadow out cut the South Fork which out cut the MEUK with outcut the Point Guard. What was more interesting was the manner in which they blunted which was very different between the two Wilson blades and the other two knives, easily noticed in the following graph :
http://i7.photobucket.com/albums/y269/CliffStamp/phil%20wilson/south%20fork/cardboard.png
All the blades start off blunting similar with linear relationships with the amount of material cut, however the rate of blunting in Wilson's knives is reduced almost immediately and the rate of loss of sharpness is cut to a small fraction of the initial rate. Specifically, in the last 10 meters they blunt as much as they did in the initial 0.5 meters. However the other two blades keep blunting at the very fast initial rate and thus they are soon not even in the same class.
When I discussed blunting with Wilson many years ago, he proposed initial blunting was deformation and late blunting was carbide and that there were two distinct stages, initial work I did supported this but later more detailed work with more points didn't show two regions but a smooth transfer and it looked like all blades had the same behavior so I was thinking the process was nonlinear as a whole, mainly a log relationship.
It turns out my viewpoint was off because the sample was biased as almost all the knives used had really high carbide volumes and thus high wear resistance. The above graph shows low alloy steels and they have different behavior which supports the carbide hypothesis. As well if you look at the difference between the two Wilson blades in detail you can notice that the Coyote Meadow has a further reduced fall off which is inline with the greater wear resistance it has due to the increased vanadium.
In regards to ease of slicing the cardboard, the cotton cutting well represents the sharpness, as the numbers climb the blades start to be unable to cut the cardboard cleanly and instead is torn. This happens at past 4 meters with the Point Guard and 9 meters with the MEUK. After 18 meters the Wilson blades are still cutting clean, if you extrapolate based on the graph for them to reach the same level of cotton performance it is a many to one advantage due to the fall off in blunting rate.
Consider for example that the South Fork after cutting 18 meters of cardboard has the same sharpness as the PoinT Guard has after cutting 1.8, a difference of a factor of ten, and this ratio actually gets bigger as more cardboard is cut because the Point Guard keeps blunting rapidly and the South Fork is at that point in the region where its blunting is really low.
An additional point of interest, amount of honing for resharpening is identical, all blades are restored back to optimal performance on a 600 DMT rod with one pass per side at 20 degrees, showing the extreme influence of a micro-beveling. Ease of sharpening in terms of setting the initial edge goes South Fork, Coyote Meadow, MEUK, Point Guard. It was very difficult to get the last two softer blades to form clean, I only used the repeat step in the above because it was necessary for them.
As a numerical ranking for sharpening, if the South Fork was a 5 the Coyote Meadow was a 4.5, very close, it was a bit lower because the low grindability requires more precision and my freehand sharpening skills are not what I would call great. If I was using a jig these would be near identical. The MEUK is much lower, easily a three, it tended to burr more readily, and was harder to get crisp and even. The Point Guard was annoying, it was easily a 1, difficult to get a very sharp edge.
In case anyone is wondering, the edge retention of the knives is *greatly* enhanced by the low angles, I also did runs where the edges were set at 10/12 primary and 20 micro-bevel with a 600 DMT rod, the edge retention was much lower on the same class of cardboard. I also ran a Black Jack small also in 52100 against the two Wilson blade in other trials just to confirm the behavior, it was also just as strongly outclassed as the MEUK.
-Cliff
-refine with 800 AO
-Cliff
