Cliff Stamp
BANNED
- Oct 5, 1998
This is the first part of some testing done on four blades supplied by Ray Kirk. The geometry is identical (as close as you can get with hand work) but the steel types are different. The purpose of the work was to illustrate not only the difference in edge holding on an abrasive and difficult to cut material, but to also look at issues with sharpening and edge durability.
The blades were supplied to me with the steel type unknown, just marked A,B,C and D. At the start of each round of testing I had a friend tape over the markings and write 1,2,3,4 on them. Once the round of testing was completed I removed the tape and noted which one was A,B,C and D. This was done to insure that no bias would be introduced into later rounds by the results of the previous ones.
Here is the main body of the work :
http://www.physics.mun.ca/~sstamp/knives/ray_kirk_test_blades.html
It contains quite a lot of numerical data (surprise) and most of the tables are quite large. This took quite some time to do. At the end I was doing 2000 cuts per round into the mats used as blunting stock and the load required to drive the blades through the mats was quite high as the mats had a heavy tight carpet weave with a thick rubber underlay, the load on average was ~100 lbs towards the end. In total considering all the cuts done over the four rounds, ~500 000 lbs of force was exerted. This was not done in a day, nor even a week.
Here is the commentary which reveals which blades are which, one has a surprise feature, and gives my interpretation of the results, why the performance went as it did :
http://www.physics.mun.ca/~sstamp/knives/ray_kirk_test_blades.txt
I would like to thank Ray for loaning me these blades. This work was only the start of what I have planned for them. I have learned quite a lot for working with them, it confirmed a lot of what I believed to be true as well as explored new ground.
-Cliff
-Cliff
