Edge Thickness / Grind Angle
I know this has been discussed over and over; however, the search feature is not working. Is there any guidelines about edge thickness or grind angle? How do you determine the thickness of the edge? Any help is greatly appreciated.
I would recommend an edge of 0.5mm.
As for the angle, I flat grind all my blades to the spine now (and convex the edge). Not sure what the angle is (depends on the knife), but this works well for me.
Hope the info helps.
I think much of the edge thickness should depend on the intended use of the knife. For a chopping knife, or rough duty, you may want a thicker edge than for a skinner. This would pretty much be up to you and your designed purpose of the knife.
Right now I am stuck with flat grind as I do not have a KMG... yet. I was just wondering if there was any "set" standard or guide lines for a knifes grind angle.
LRB is correct. The edge should be geared to the intended use and style of knife. Paul Bos told me that to prevent warping, he prefers .030 or thicker. I grind to about .022 normally, for a hunter. for a fighter .030 works just fine. For a whitteling, or carving knife, I may go as low as .010, heat treat myself, and further refine, and thin when the heat treat is complete. This however requires that the grinds be dead even, both side to side, and for the length of the edge. Otherwise, there may be considerable warpage. Great care also must be exercised in th finish grind and polishing of such a thin edge, or temper loss will occur. On my most finely ground edges, you can flex the edge to the side with just thumbnail pressure. Extremely good heat treat is required for this type of edge to hold up in use however. With a typical flat grind,just about anything will work. Just take care to not leave a sharp edge running along the intended edge to start a stress riser, that could cause a crack in H/T. Flat grinding makes life a whole lot easier in many ways. Its the simplest to produce, and by far the easiest to control in heat treat. If you have the patients, and skill, an deep hollow has its own rewards. Mike
