Edgepro Apex stones
My 120 grit stone has seen alot of action and is starting to dish in the middle. How deep can the dish get before stone replacement is needed?
They have a lot of life in them,he sells a glass and sand to even the stone to new,look at his web................
I does need to be lapped flat though as noted. Otherwise it starts to form a convex edge when you use it.
Gary
You can use up a DMT extra-course whetstone, a flat piece of concrete, or get the silicon carbide or the stone leveling kit directly from Ben/EP.
You shouldn't let it dish at all. Flatten them after every couple of knives. It only takes a few minutes, you can do it on a cheap new Silicon Carbide stone ($3-$5 in any hardware store) or if you happen to live where there is a nice smooth cement paving stone, use that. Just put a strip down the center, end to end, with a marker, rub your EdgePro stone back and forth until there is no more marker showing, and you're done. Five minutes at most.
