- May 3, 2001
Hi All,
I have a new Edgepro Apex and there are three issues I need some help with. I asked Ben Dale but didn't really understand his answer.
1. Finding the edge: The Edgepro system recommends using a marker and finding the edge angle that the knife already has on it. Then, sharpen using this angle. But I'd like to use my Sharpmaker for touch-ups because it's more convenient (it's never worked well for me, but I thought I'd give it another chance). So should I reprofile my blades to 40 or 30 degrees just so I can use the Sharpmaker? Or is it really worth just keeping the edge it came with from the factory unless I have a specific need for something else? Then the Sharpmaker won't work, right? I do have a leather strop and green compound I can use in place of the Sharpmaker, if that will work just as well for touch-ups.
2. Which grits to use? Let's say I have a dull kitchen knife. If I want to reprofile it to 30 degrees so I can use the Sharpmaker on it, I will use the coursest grit (100) to do this, then go to medium (180) then fine (220). Is it worth going beyond that for a general purpose kitchen knife? If the knife is dull but I don't want to reprofile it, should I start with medium (180)? How about for a general-purpose folder?
3. Removing the burr: Is it correct that just by going to a higher grit and using light strokes that the burr will be removed and I will have a good edge? If this is not correct, how do I remove the burr?
Thanks a lot for any assistance!
Johnny
Johnny
